MaxSHOT 3D™
Transition from complex photogrammetry to point-and-shoot simplicity. Elevate your measurement accuracy for large-scale projects and ensure first-time-right data acquisition.
MaxSHOT 3D™ | Large-Scale Optical Coordinate System
Unprecedented Accuracy for Massive Components
The MaxSHOT 3D is a game-changer for product development, manufacturing, and quality control teams working with large-scale parts ranging from 2 to 10 meters. By adding the power of photogrammetry to the measurement process, it delivers unmatched volumetric accuracy and repeatability. Imagine achieving precision better than 0.015 mm/m—the MaxSHOT 3D makes this a reality, providing peace of mind that your measurements are always right on the dot.
Designed to eliminate the complexity traditionally associated with photogrammetry, the MaxSHOT 3D features a sophisticated user guidance technology. Its intelligent software autonomously guides technicians of all levels—even those without metrology expertise—through the data acquisition process. This ensures high-quality results while significantly reducing the risk of human error and slashing the time required for large-volume inspections.
The MaxSHOT 3D is more than a standalone device; it is a force multiplier when combined with other Creaform technologies. Whether used with the HandySCAN 3D, HandyPROBE, or MetraSCAN 3D, it significantly increases the measurement range and accuracy of your existing tools. This integrated ecosystem provides a seamless “Scan-to-Position” workflow, making it the definitive solution for aerospace, heavy industry, and transportation sectors.
Accuracy
Accuracy of 0.015mm
Scanning Area
Worldwide support
Worldwide support
VDI/VDE 2634 Part 1
ISO 17025
Integrated and streamlined process
Real-Time Feedback & Guidance
Never take a bad measurement again. The MaxSHOT 3D features a laser-projected frame with live GO/NO-GO feedback directly on the part. This visual guidance tells you immediately if the photo quality is optimal or if you need to adjust your position. Combined with VXshot’s step-by-step diagnostic tools, the system ensures that every captured image is valid before you move to the next step.
Extreme Accuracy on a Large Scale
Engineered for the most demanding metrology projects, the MaxSHOT 3D is up to 40% more accurate than previous generations on large-sized parts. With a volumetric accuracy of up to 0.015 mm/m and reliable performance based on VDI/VDE 2634 Part 1 standards, it provides the precise data required for complex alignments, quality assessments, and large-scale reverse engineering.
TruPortability for the Shop Floor
High-precision photogrammetry is no longer confined to the laboratory. The MaxSHOT 3D is remarkably lightweight (only 0.79 kg) and rugged enough to handle harsh industrial environments. The entire system and its accessories fit into a single portable carrying case, allowing for quick setup in less than two minutes directly on the production floor or at remote sites.
Maximized User Comfort & Speed
Designed with ergonomics in mind, the MaxSHOT 3D features multifunction buttons that allow for easy interaction with the software without returning to the computer. This streamlined process, combined with an ultra-short learning curve, allows any member of your team to master the technology quickly. The result is a drastically shorter measuring time on large parts and a more efficient overall workflow.
perspective_left_maxshot3d-2_en_1
Technical Specifications
Discover how the MaxSHOT 3D measures up in terms of speed and accuracy.
MaxSHOT NEXT™ MaxSHOT NEXT MaxSHOT NEXT™|ELITE MaxSHOT NEXT ELITE
Volumetric Accuracy 0.025 mm/m (0.0003 in/ft) 0.015 mm/m (0.00018 in/ft)
Average deviation 0.008 mm/m (0.0001 in/ft) 0.005 mm/m (0.00006 in/ft)
Volumetric accuracy (when combined with)
HandySCAN 3D|BLACK Series
HandySCAN 3D|SILVER Series
0.020 mm + 0.025 mm/m (0.0008 in + 0.0003 in/ft) 0.020 mm + 0.015 mm/m (0.0008 in + 0.00018 in/ft)
Go!SCAN SPARK™ 0.050 mm + 0.025 mm/m (0.0020 in + 0.0003 in/ft) 0.050 mm + 0.015 mm/m (0.0020 in + 0.00018 in/ft)
HandyPROBE Next™ >
MetraSCAN BLACK+™
0.035 mm + 0.025 mm/m (0.0014 in + 0.0003 in/ft) 0.035 mm + 0.015 mm/m (0.0014 in + 0.00018 in/ft)
HandyPROBE Next™|Elite
MetraSCAN BLACK+™|Elite
0.025 mm + 0.025 mm/m (0.0009 in + 0.0003 in/ft) 0.025 mm + 0.015 mm/m (0.0009 in + 0.00018 in/ft)
Weight 0.79 kg (1.75 lb)
Dimensions (LxWxH) 104 x 180 x 115 mm (4.1 x 7.1 x 4.5 in)
Operating temperature range 5-40°C (41-104°F)
Operating humidity range (non-condensing) 10-90%
Certifications EC Compliance (Electromagnetic Compatibility Directive, Low Voltage Directive), IP50, WEEE, Laser class (2M)
Creaform Metrology Suite™
Proven, reliable 3D metrology software for real-world challenges
Master your measurement workflow with a single, integrated ecosystem. The suite combines four powerful modules—Scan-to-CAD, Inspection, Automation, and Dynamic Tracking—to provide a seamless solution for your most demanding real-world challenges.
