HandyPROBE | Next-Generation Portable Optical CMM
Transition from rigid measuring arms to total wireless freedom. Boost measurement speed and achieve laboratory-grade precision directly on the shop floor.
Prenosno cmm tipalo
HandyPROBE
Professional Probing Without the Constraints of Arms
The HandyPROBE stands as the most advanced portable coordinate measuring machine (PCMM) designed specifically for the demands of modern manufacturing. Unlike traditional measuring arms, which are limited by their joints and fixed bases, the HandyPROBE offers a completely wireless and arm-free experience. This allows quality control professionals to perform high-accuracy measurements anywhere on the shop floor with total freedom of movement.
At the core of the HandyPROBE’s performance is its optical tracking technology. By utilizing a C-Track optical tracker, the system maintains constant accuracy through dynamic referencing. This means the part, the probe, and the coordinate system are always synchronized—even if the part moves or the environment is unstable. It is a robust solution that brings laboratory-grade precision directly into the heart of production.
Designed for efficiency and ease of use, the HandyPROBE streamlines the inspection process for complex parts and assemblies. Its ergonomic design and “point-and-shoot” simplicity enable users to capture geometrical features with incredible speed. Whether used for part-to-CAD analysis, first article inspection, or tool adjustments, the HandyPROBE provides the reliable data needed to ensure uncompromising quality at every stage.
Accuracy
Accuracy of 0.025mm
Scanning Area
Worldwide support
Worldwide support
Certified ISO 17025
ISO 17025
Patented Technology
Dynamic Referencing & Shop-Floor Accuracy
The HandyPROBE is engineered to perform in real-world industrial environments. Thanks to its dynamic referencing capability, the system is completely insensitive to environmental instabilities like vibrations or thermal changes. You can move the part or the tracker during the measurement process without losing alignment, ensuring consistent, metrology-grade results every time.
Greater & Extendable Measurement Volume
Freedom of movement is the hallmark of the HandyPROBE. Because it has no mechanical arms or cables, it can easily measure parts of all sizes, from small components to large-scale assemblies. With the Automatic Volume Extension (AVE) feature, the measurement volume can be expanded effortlessly, allowing for large-scale inspection without the need for complex “leapfrogging.”
Arm-Free Design for Maximum Ergonomics
Say goodbye to the physical strain and limited reach of traditional articulated arms. The HandyPROBE’s lightweight, wireless design allows operators to access hard-to-reach areas and internal features with ease. This ergonomic advantage not only improves user comfort but also significantly speeds up the inspection cycle for complex geometries.
Integrated Metrology Ecosystem
The HandyPROBE is fully integrated with Creaform’s VXelements software, providing a seamless workflow from data acquisition to final reporting. It can also be combined with MetraSCAN 3D to create a complete scanning and probing solution. This versatility ensures that you have the right tool for every task, whether it’s high-speed surface scanning or high-precision feature probing.
Merjenje izvrtin s prenosno cmm napravo handy probe
Technical Specifications
Innovative technology providing unmatched accuracy and speed for professional metrology applications.
HandyPROBE Next+™ HandyPROBE Next HandyPROBE Next+™ Elite HandyPROBE Next Elite
Probing accuracy0.030 mm (0.0012 in)0.025 mm (0.0009 in)
Volumetric accuracy
9.1 m³ (320 ft³)
0.086 mm (0.0034 in)0.064 mm (0.0025 in)
Volumetric accuracy
16.6 m³ (586 ft³)
0.122 mm (0.0048 in)0.078 mm (0.0031 in)
Automatic Volume Extension accuracy0.035 mm + 0.020 mm/m (0.0014 in + 0.00024 in/ft)0.025 mm + 0.015 mm/m (0.0009 in + 0.00018 in/ft)
Single point repeatability0.030 mm (0.0012 in)0.025 mm (0.0009 in)
Acceptance testBased on ISO 10360-12: (E) MPEP / ASME B89.4.22
Part size range (recommended)0.2–6 m (0.7–20 ft)
Compatible software3D Systems (Geomagic® Solutions), InnovMetric Software (PolyWorks), Metrologic Group (Metrolog X4), New River Kinematics (Spatial Analyzer), Verisurf, Dassault Systèmes (CATIA V5, SOLIDWORKS), PTC (Creo), Siemens (NX, Solid Edge), Autodesk (Inventor, PowerINSPECT)
WeightProbe: 0.5 kg (1.1 lb) / C-Track: 5.7 kg (12.5 lb)
Dimensions (LxWxH)Probe: 68 x 157 x 340 mm (2.7 x 6.2 x 13.4 in)
C-Track: 1031 x 181 x 148 mm (40.6 x 7.1 x 5.8 in)
Connection standard1 X USB 3.0
Operating temperature range5-40 °C (41-104 °F)
Operating humidity range (non-condensing)10-90%
CertificationsEC Compliance (Electromagnetic Compatibility Directive, Low Voltage Directive), compatible with rechargeable batteries (when applicable), IP50, WEEE
Creaform Metrology Suite™
Proven, reliable 3D metrology software for real-world challenges
Master your measurement workflow with a single, integrated ecosystem. The suite combines four powerful modules—Scan-to-CAD, Inspection, Automation, and Dynamic Tracking—to provide a seamless solution for your most demanding real-world challenges.
