MetraSCAN 3D
The Ultimate Optical CMM Scanner for Shop-Floor Metrology.
metrascan-3d-left-side
MetraSCAN 3D
Unmatched Speed and Precision in Any Environment
The MetraSCAN 3D stands as the most complete metrology solution for high-performance 3D scanning and inspection directly on the production floor. Engineered to perform in harsh industrial conditions, it delivers shop-floor accuracy that is completely insensitive to environmental instabilities, such as vibrations or thermal variations. By combining metrology-grade precision with total freedom of movement, it redefines what is possible in large-scale dimensional quality control.
At the heart of the system is the C-Track optical tracker, which enables dynamic referencing and ensures that the part, the scanner, and the coordinate system remain perfectly aligned even if they move. This optical CMM approach eliminates the need for rigid setups and allows for the rapid acquisition of highly accurate data on parts ranging from 0.2 to 10 meters in size, regardless of their material, color, or surface finish.
Designed for maximum throughput, the MetraSCAN 3D features a high-density blue laser grid that captures up to 2,500,000 measurements per second. Whether used for first article inspection, part-to-CAD analysis, or reverse engineering, this fully integrated solution empowers QA professionals to execute complex workflows with unprecedented speed and efficiency, significantly reducing inspection cycle times.
Accuracy
Accuracy of 0.025mm
Worldwide support
Worldwide support
Scanning Area
Certified ISO 17025
ISO 17025
Patented Technology
Scanning Area
Versatile 3-in-1 System
ISO 17025
Dynamic Referencing
Dynamic Referencing & Shop-Floor Accuracy
The MetraSCAN 3D is built for the “real world.” Thanks to its optical tracking system, the measurement accuracy is never compromised by the surrounding environment. Both the part and the scanner can move freely during the process, ensuring consistent, laboratory-grade results (up to 0.025 mm) directly in the manufacturing cell or on the shop floor.
Versatility with Probing Capabilities
When combined with the optional HandyPROBE, the MetraSCAN 3D becomes a dual-function powerhouse. Users can seamlessly switch between high-speed 3D scanning for surface inspection and high-accuracy probing for geometrical features like holes, planes, and cylinders. This “all-in-one” approach eliminates the need for multiple devices, streamlining the entire metrology process.
Mastery of Complex Surfaces
Equipped with 30 blue laser lines, the MetraSCAN 3D is optimized to scan even the most challenging materials without any surface preparation. From high-gloss chrome and deep blacks to multi-colored assemblies, the system captures fine details and complex geometries in real-time, providing clean, high-resolution meshes in seconds.
Extendable Measurement Volume
Unlike traditional portable CMMs, the MetraSCAN 3D offers an easily extendable measurement volume. Through the Automatic Volume Extension (AVE) feature, users can measure large parts without the need for manual leapfrogging or complex re-alignments. This capability ensures that data integrity is maintained across the entire volume, making it the ideal choice for aerospace, automotive, and heavy industry.
metrascan-3d-with-lasers_en_1
Technical Specifications
The most complete 3D scanning solution for metrology-grade measurements and inspections in all work environments.
MetraSCAN BLACK+™ MetraSCAN BLACK MetraSCAN BLACK+Elite™ MetraSCAN BLACK Elite MetraSCAN BLACK2™ MetraSCAN BLACK Elite [S]
Accuracy 0.035 mm (0.0014 in) 0.025 mm (0.0010 in) 0.025 mm (0.0010 in)
Volumetric accuracy
9.1 m³ (320 ft³)
0.075 mm (0.0031 in) 0.064 mm (0.0025 in) 0.064 mm (0.0025 in)
Volumetric accuracy
16.6 m³ (586 ft³)
0.100 mm (0.0039 in) 0.075 mm (0.0031 in) 0.075 mm (0.0030 in)
Volumetric accuracy
46.7 m³ (1650 ft³)
N/A N/A 0.100 mm (0.0039 in)
Automatic Volume Extension Accuracy 0.035 mm + 0.020 mm/m (0.0014 in + 0.00024 in/ft) 0.025 mm + 0.015 mm/m (0.0010 in + 0.00018 in/ft) 0.025 mm + 0.015 mm/m (0.0010 in + 0.00018 in/ft)
Stand-alone mode accuracy N/A N/A 0.020 mm + 0.040 mm/m (0.0010 in + 0.00048 in/ft)
Form error (Sphere) 0.035 mm (0.0014 in) 0.025 mm (0.0010 in) 0.025 mm (0.0010 in)
Form error (Flat) 0.060 mm (0.0024 in) 0.045 mm (0.0018 in) 0.045 mm (0.0018 in)
Probing accuracy with HandyPROBE Next+ 0.030 mm (0.0012 in) 0.025 mm (0.0010 in) 0.025 mm (0.0010 in)
Acceptance test Based on VDI/VDE 2634 part 3 and ISO 10360
Tracking modes C-Track mode (Targetless, Dynamic Tracking) C-Track mode (Targetless, Dynamic Tracking) C-Track mode (Targetless, Dynamic Tracking) + Stand-alone mode
Setup Assistance tools N/A Included Included
Automatic Shutter N/A N/A Included
Measurement capabilities (at a working distance of 0.3 m (1 ft))
Pin 0.750 mm (0.0295 in) 0.750 mm (0.0295 in) 0.750 mm (0.0295 in)
Hole 1.250 mm (0.0492 in) 1.250 mm (0.0492 in) 1.250 mm (0.0492 in)
Step 0.025 mm (0.0010 in) 0.025 mm (0.0010 in) 0.025 mm (0.0010 in)
Wall 0.500 mm (0.0197 in) 0.500 mm (0.0197 in) 0.500 mm (0.0197 in)
Measurement resolution 0.025 mm (0.0010 in) 0.025 mm (0.0010 in) 0.025 mm (0.0010 in)
Mesh resolution 0.100 mm (0.0039 in) 0.100 mm (0.0039 in) 0.100 mm (0.0039 in)
Measurement rate 1,800,000 measurements/s 1,800,000 measurements/s 2,500,000 measurements/s
Light source 30 blue laser lines (+ 1 extra line) 30 blue laser lines (+ 1 extra line) 46 blue laser lines (+ 1 extra line)
Scanning area 310 x 350 mm (12.2 x 13.8 in) 310 x 350 mm (12.2 x 13.8 in) 310 x 350 mm (12.2 x 13.8 in)
Stand-off distance 300 mm (11.8 in) 300 mm (11.8 in) 300 mm (11.8 in)
Depth of field 250 mm (9.8 in) 250 mm (9.8 in) 250 mm (9.8 in)
Working Distance (C-Track) Up to 4.2 m (13.8 ft) Up to 4.2 m (13.8 ft) Up to 6.0 m (19.7 ft)
Part size range (recommended) 0.2–6 m (0.7–20 ft) 0.2–6 m (0.7–20 ft) 0.2–10 m (0.7–32.0 ft)
General Specifications
Output formats .dae, .fbx, .ma, .obj, .ply, .stl, .txt, .wrl, .x3d, .x3dz, .zpr, .3mf .dae, .fbx, .ma, .obj, .ply, .stl, .txt, .wrl, .x3d, .x3dz, .zpr, .3mf .dae, .fbx, .ma, .obj, .ply, .stl, .txt, .wrl, .x3d, .x3dz, .zpr, .3mf
Compatible software 3D Systems (Geomagic® Solutions), InnovMetric Software (PolyWorks), Metrologic Group (Metrolog X4), New River Kinematics (Spatial Analyzer), Verisurf, Dassault Systèmes (CATIA V5, SOLIDWORKS), PTC (Creo), Siemens (NX, Solid Edge), Autodesk (Inventor, PowerINSPECT). 3D Systems (Geomagic® Solutions), InnovMetric Software (PolyWorks), Metrologic Group (Metrolog X4), New River Kinematics (Spatial Analyzer), Verisurf, Dassault Systèmes (CATIA V5, SOLIDWORKS), PTC (Creo), Siemens (NX, Solid Edge), Autodesk (Inventor, PowerINSPECT). 3D Systems (Geomagic® Solutions), InnovMetric Software (PolyWorks), Metrologic Group (Metrolog X4), New River Kinematics (Spatial Analyzer), Verisurf, Dassault Systèmes (CATIA V5, SOLIDWORKS), PTC (Creo), Siemens (NX, Solid Edge), Autodesk (Inventor, PowerINSPECT).
Weight Scanner: 1.49 kg (3.28 lb)
Probe: 0.5 kg (1.1 lb)
C-Track: 5.7 kg (12.5 lb)
Dimensions (LxWxH) Scanner: 289 x 235 x 296 mm
Probe: 68 x 157 x 340 mm
C-Track: 1031 x 181 x 148 mm
Connection standard 1 X USB 3.0 1 X USB 3.0 1 X USB 3.0
Operating temperature range 5-40 °C (41-104 °F) 5-40 °C (41-104 °F) 5-40 °C (41-104 °F)
Operating humidity range 10-90% 10-90% 10-90%
Certifications EC Compliance (Electromagnetic Compatibility Directive, Low Voltage Directive), compatible with rechargeable batteries (when applicable), IP50, WEEE EC Compliance (Electromagnetic Compatibility Directive, Low Voltage Directive), compatible with rechargeable batteries (when applicable), IP50, WEEE EC Compliance (Electromagnetic Compatibility Directive, Low Voltage Directive), compatible with rechargeable batteries (when applicable), IP50, WEEE
Creaform Metrology Suite™
Proven, reliable 3D metrology software for real-world challenges
Master your measurement workflow with a single, integrated ecosystem. The suite combines four powerful modules—Scan-to-CAD, Inspection, Automation, and Dynamic Tracking—to provide a seamless solution for your most demanding real-world challenges.
