HandySCAN 3D | MAX Series™
Large-Scale Metrology Reimagined: Unmatched Speed and Precision for Massive Parts.
Engineered for Scale, Optimized for Performance
The HandySCAN 3D | MAX Series is specifically designed to tackle the complexities of measuring large parts and assemblies. Combining a wide scanning field with Creaform’s signature metrology-grade accuracy, this series eliminates the traditional challenges of large-scale inspection, delivering reliable data where standard scanners reach their limits.
By integrating a massive scanning area and extra-large measurement depth, the MAX Series allows for rapid data acquisition without sacrificing precision. This enables professionals in aerospace, heavy industry, and energy to perform comprehensive quality control and reverse engineering on massive components with significantly reduced setup times.
The MAX Series stands as the definitive solution for large-scale 3D measurement. Equipped with an embedded screen and fully integrated workflows, the MAX Series delivers a simpler, more intuitive scan-to-report experience that significantly accelerates quality control and quality assurance (QC/QA) processes.
Embedded Screen for Streamlined Scanning
The HandySCAN 3D MAX Series features a built-in display that significantly improves ergonomics on the shop floor. By keeping scan data and the physical part within the same line of sight, it creates a much more comfortable and natural scanning experience. Providing real-time mesh visualization and guided workflows directly on the device, the embedded screen simplifies onboarding for new operators and substantially boosts overall operational efficiency.Accredited Accuracy on Any Location
Fast and Versatile Work on Large Parts
Optimized Scan-to-Report Workflow
With high-speed data acquisition and immediate operator feedback, the entire inspection cycle is drastically shortened. The instant mesh generation feature immediately produces ready-to-use files right after scanning. For QC and QA teams, this means a smooth, automated transition from raw data to the final measurement report without any unnecessary downtime.Technical Specifications
Innovating technology that provides accuracy, simplicity, portability as well as real speed to your metrology-grade applications.
HandySCAN MAX EVO™
HandySCAN MAX EVO Elite™
| Accuracy | 0.150 mm (0.0059 in) | 0.075 mm (0.0030 in) |
| Volumetric accuracy (based on part size) |
0.150 mm + 0.020 mm/m (0.0059 in + 0.00024 in/ft) | 0.075 mm + 0.010 mm/m (0.0030 in + 0.00012 in/ft) |
| Measurement capabilities (at a working distance of 0.5 m (1.65 ft)) | ||
| Pin | 2.50 mm (0.0984 in) | 2.50 mm (0.0984 in) |
| Hole | 3.50 mm (0.1378 in) | 3.50 mm (0.1378 in) |
| Step | 0.04 mm (0.0016 in) | 0.04 mm (0.0016 in) |
| Wall | 2.00 mm (0.0787 in) | 2.00 mm (0.0787 in) |
| Measurement resolution | 0.04 mm (0.0016 in) | 0.04 mm (0.0016 in) |
| Mesh resolution | 0.4 mm (0.0157 in) | 0.4 mm (0.0157 in) |
| Measurement rate | 2,250,000 measurements/s | 2,250,000 measurements/s |
| Light source | 38 blue laser lines + Laser Pointer | 38 blue laser lines + Laser Pointer |
| Scanner Controls | 4.3" Touchscreen display + physical buttons | 4.3" Touchscreen display + physical buttons |
| Photo Camera | 12 MP, AR-enabled | 12 MP, AR-enabled |
| Real-time Calibration | Included | Included |
| Automatic Alignment & Clean-up | Included | Included |
| Advanced Software Features | N/A | Included |
| Scanning area | Up to 1.4 x 1.5 m (4.6 x 5.1 ft) | Up to 2.0 x 2.4 m (6.7 x 7.9 ft) |
| Working distance | 0.45 to 1.60 m (1.5 to 5.2 ft) | 0.30 to 2.50 m (1.0 to 8.2 ft) |
| Depth of field | 1.15 m (3.8 ft) | 2.20 m (7.2 ft) |
| Part size range (recommended) | 1–10 m (3.3–32.8 ft) | 1–15 m (3.3–49.2 ft) |
| General Specifications | ||
| Output formats | .dae, .fbx, .ma, .obj, .ply, .stl, .txt, .wrl, .x3d, .x3dz, .zpr, .3mf | .dae, .fbx, .ma, .obj, .ply, .stl, .txt, .wrl, .x3d, .x3dz, .zpr, .3mf |
| Compatible software | 3D Systems (Geomagic®), InnovMetric Software (PolyWorks), Metrologic Group (Metrolog X4), New River Kinematics (Spatial Analyzer), Verisurf, Dassault Systèmes (CATIA V5, SOLIDWORKS), PTC (Creo), Siemens (NX, Solid Edge), Autodesk (Inventor, PowerINSPECT). | 3D Systems (Geomagic®), InnovMetric Software (PolyWorks), Metrologic Group (Metrolog X4), New River Kinematics (Spatial Analyzer), Verisurf, Dassault Systèmes (CATIA V5, SOLIDWORKS), PTC (Creo), Siemens (NX, Solid Edge), Autodesk (Inventor, PowerINSPECT). |
| Weight | 1.28 kg (2.8 lb) | 1.28 kg (2.8 lb) |
| Dimensions (LxWxH) | 86 x 121 x 419 mm (3.4 x 4.8 x 16.5 in) | 86 x 121 x 419 mm (3.4 x 4.8 x 16.5 in) |
| Connection standard | 1 X USB 3.0 | 1 X USB 3.0 |
| Operating temperature range | 5-40 °C (41-104 °F) | 5-40 °C (41-104 °F) |
| Operating humidity range | 10-90% | 10-90% |
| Certifications | EC Compliance (Electromagnetic Compatibility Directive, Low Voltage Directive), compatible with rechargeable batteries (when applicable), IP50, WEEE | EC Compliance (Electromagnetic Compatibility Directive, Low Voltage Directive), compatible with rechargeable batteries (when applicable), IP50, WEEE |
Creaform Metrology Suite™
Proven, reliable 3D metrology software for real-world challenges
