Automated Measurement and Robotic 3D Inspection | Industry 4.0
Increase production throughput and eliminate quality control bottlenecks. Creaform robotic cells enable automated 3D scanning and immediate metrological analysis of products directly within your production process.
Automate 3D Measurements and Quality Control
In series and high-volume production, manual measurements can create bottlenecks in maintaining fast and repeatable quality control. Measurement automation using Creaform solutions, such as MetraSCAN-R and CUBE-R, enables automated 3D data acquisition, comparison against reference CAD models, and rapid deviation analysis.
At IB-CADDY, we assist with selecting and implementing solutions for automated 3D measurement, robotic scanning, and quality control on the shop floor.
Benefits of Robotic 3D Scanning in Manufacturing
Automated 3D scanning delivers a standardized measurement process, repeatable data capture, and seamless integration of quality control into the manufacturing line. Why automate your measurement process?
Higher Throughput: An automated workflow allows for more efficient inspection of larger production volumes.
Repeatable Measurement Process: The robot executes the exact defined path consistently across every cycle.
Faster Results Analysis: 3D data can be compared directly to the reference CAD model to analyze deviations without delay.
Production Feedback: Inspection results allow for faster detection of deviations and immediate corrective actions in the manufacturing process.
Technology That Requires No Rigid Fixturing
One of the greatest technological achievements of Creaform systems is Optical Tracking. This allows the system to maintain micron-level accuracy even in environments with vibrations or robot movements.
Dynamic Referencing: The VXscan-R system constantly monitors the position of both the part and the robot, eliminating the need for expensive and complex fixtures.
Smart Factory Integration: Solutions are ready to connect with your Programmable Logic Controllers (PLC) and databases for comprehensive quality monitoring.
Versatility on Challenging Surfaces: Equally effective at measuring dark materials, carbon fiber, and reflective metals without pre-treatment.
Complete solutions for automated quality control
VXscan-R Software: The Digital Twin of Your Inspection
The success of automation relies on intelligent software. VXscan-R serves as an environment for digital planning and execution of robotic measurements:
Offline Programming: Preparation of robot measurement paths on a digital twin (CAD model) before the physical part is even manufactured.
Collision Avoidance: Advanced algorithms automatically optimize robot paths and prevent any damage to the equipment or the product.
Automated Quality Reports: Immediately after the cycle is finished, the system exports a detailed report in your preferred format, ready for archiving or the client.
Solutions for Every Level of Automation
From small parts to entire car bodies – we offer flexible systems for various needs:
CUBE-R: A comprehensive, safe, and “turn-key” ready measuring cell that replaces several traditional CMM machines.
MetraSCAN-R: A robotic scanner that can be integrated onto any industrial robotic arm (Fanuc, ABB, Kuka, etc.).
Custom Solutions: Design of custom measuring stations tailored to your production space and product specifications.
Choose right solution for automated quality control
The choice of equipment depends on your specific needs for accuracy and object size.
Accuracy: 0.025 mm
Probing
Light Surce: 30 blue laser crosses (+1 extra line)
Accreditation: ISO 17025
No set-up required
Patented technology
A
Accuracy: 0.025 mm
A
High resolution
Short cycle time
Repeatable results
Accuracy: 0.020 mm
Light Surce: 46 Blue laser lines (+1 extra line) + laser pointer
Optimal UX
Fastest time from scan to reporting
Wireless capability
Accuracy: 0.075 mm
Light Surce: 38 Blue laser lines
A
Large scanning area
Scan-to-mesh in seconds
A
If you can’t find the measuring equipment you are looking for, check out our FARO website for more solutions.
Frequently Asked Questions (FAQ)
Is programming a robotic cell difficult for our employees?
Thanks to the VXscan-R module, programming is intuitive. An operator does not need in-depth knowledge of robot coding, as the system generates most paths automatically based on the CAD model.
How safe is the CUBE-R system for shop-floor use?
CUBE-R is a fully enclosed system with all safety certifications, meaning it can operate directly alongside employees without risk of injury.
Is it possible to integrate robotic 3D scanning into an existing production line?
Yes, Creaform’s robotic 3D scanners are designed for easy integration with any industrial robotic arm. Our team at IB-CADDY supports you throughout the entire integration process, from connecting the scanner to your robot controllers to integration with existing control systems (PLCs).
Choose the Right 3D Scanner for Your Project
Experience the Gold Standard in 3D Metrology
