Reverse Engineering with 3D Scanning | Creaform Reverse Engineering
Bridging the gap between physical objects and CAD designs. Discover the most advanced Creaform solutions for fast and accurate geometry reconstruction from point clouds into parametric models.
Ročni 3D skener Creaform HandySCAN Black Elite med procesom vzvratnega inženiringa strojnega dela v industrijskem okolju.
Reverse Engineering: Professional Solutions for Digital Reconstruction
Reverse engineering is the process of capturing data from an existing physical product, component, or assembly to create or update its digital representation.
Using 3D scanning, we can quickly capture the complex geometry of a physical part and convert it into digital 3D data. This data serves as the foundation for further processing, geometry reconstruction, and CAD model creation.
This approach is particularly useful when original technical documentation or CAD models are missing, incomplete, or no longer represent the actual state of the part.
At IB-CADDY, we help you select the right Creaform solution for 3D scanning and reverse engineering, from initial geometry capture to advanced 3D data processing.
Why Choose Creaform Technology for Reverse Engineering?
When transferring geometry to CAD, conventional scanners often face limitations in accuracy and data processing. Creaform software and scanners are designed to perform in the most demanding environments – directly in R&D departments or on the shop floor.
Key Benefits for Engineers:
  • Accurate Geometry Capture: Professional 3D scanners enable the capture of complex shapes, edges, and surfaces with high measurement accuracy.
  • Fast 3D Data Acquisition: The entire geometry of a component can be digitized in a short time, even with complex shapes.
  • Mobile 3D Scanning: Perform measurements directly on the shop floor, in the R&D workshop, or in the field.
  • CAD Environment Integration: Data can be processed and prepared for further work in your CAD environment.
  • Digitization of Existing Products: Physical components can be used as the foundation for creating, updating, or verifying a digital model.
Technology Solving Your Challenges: VXmodel and HandySCAN
Standard reverse engineering processes are often time-consuming due to data noise and complex surfaces. Creaform solutions (HandySCAN Black and HandySCAN EVO series) utilize blue laser technology, enabling:
  • Scanning Without Spraying: Forget about matting powders; laser beams work exceptionally well on chrome and high-gloss black surfaces.
  • High Detail Resolution: Detection of the finest edges and transitions, which is critical when reconstructing complex castings.
  • LiveTransfer Functionality: Direct transfer of parameters and geometry into the feature tree of your CAD program.
Demonstration of reverse Ingineering
Process in Practice: How We Speed Up Your Development Cycle
A professional handheld 3D scanner is just the beginning. The real value is revealed in the speed of data processing, where Creaform’s VXmodel software enables the fastest path to the finish line:
Entity Extraction
Instead of manually sketching over the point cloud, VXmodel automatically recognizes geometric shapes.
Auto-Surfacing
For complex, organic shapes, you can create accurate NURBS surfaces with a single click.
Model Validation
Instant comparison of the reconstructed CAD model with the original scan to confirm accuracy.
Where is reverse engineering used?
3D scanning and reverse engineering are useful wherever an existing physical product needs to be converted into usable digital data.
  • Tooling and Foundry Industry: Digitization of existing tools, molds, and other components for which original CAD documentation is no longer available or no longer matches the actual state.
  • Spare Parts: Creating a digital foundation for legacy or damaged components where technical documentation is unavailable.
  • Product Development and Modernization: Capturing an existing product as a baseline for developing a new version, modifying the design, or making product improvements.
  • Customizing Components: Digitization of existing assemblies and components to develop parts that must fit the current geometry precisely.
  • Digitization of Existing Products: Converting physical products into digital 3D data for archiving, further development, inspection, or remanufacturing.
Prikaz programske opreme Creaform VXmodel za pretvorbo oblaka točk v parametrični CAD model s funkcijo LiveTransfer.
Which 3D scanner is suitable for reverse engineering?
Choosing the right 3D scanner for reverse engineering depends primarily on the size and geometry of the part, the required accuracy, the material and surface type, and the level of detail you need to capture.
Frequently Asked Questions (FAQ)
Which Creaform model is best for reverse engineering?
For the highest accuracy and complex surfaces, we recommend the HandySCAN Black Elite. For general industrial use with a focus on speed, the HandySCAN EVO is an excellent choice.
Yes, VXmodel supports LiveTransfer for SolidWorks, Autodesk Inventor, Siemens NX, and other leading CAD platforms.
By using VXmodel, the time required to transition from a scan to a clean CAD model is reduced by up to 75% compared to traditional methods of modeling over a point cloud.
Ready to Digitalize Your Products?
Enhance your development processes with advanced 3D scanning. Discover Creaform handheld 3D scanners for accurate geometry capture, reverse engineering, and product digitization.
kontrola kvalitete s 3d skenerjem
